RE: recommended battery for 7 servos
The battery size will vary a lot depending on if the plane is set up with huge 3D throws or just normal precision throws. For 3D you'd need at least 1000mah and I'd go with 1500+ mah so I can fly all afternoon on a single charge. Also depends how many flight you want out of it without recharging.
