does it come with the flat bed trailer option? lol nice job
ORIGINAL: rcguy!
Hey Gang,
Thought I'd post some pictures of my own design fueling station. I have the DreamworksRC pump running at @8 1/2 volts. The 12V air compressor is for the retracts! Pretty cool eh? I built a regulator circuit with a LM338K to drop the 12VDC to 8 1/2. The battery is a 12VDC at 4 1/2 AMPS. The aluminum mount is .050" thick and just hangs from the filler neck.
The last photo is melted Monokote on the bottom of the fuse. May have happened when I taxied downwind or sometime like that. I have some .004" stainless sheet I got from McMaster Carr and will install it all the way to the aft end of the fuse.
I'll install the new air tank and report the final "dry" weight and let you all know how the Cemter of Gravity works out.
Later...Dave Rigotti
