It's going to be 38 here in Adelaide on Sunday (100 for the unmetricified
). But the first thing needed for a fast start is a plug that's glowing just right. I use a power panel and set each plug individually because there can be a huge difference in the power different plugs can draw. Next thing is getting the right amount of prime (sorry if it seems I'm telling you how to suck eggs) and then spreading it up into the cylinder. With the plug connected you should feel a bump when you turn the prop over slowly which is the engine telling you it's ready to start. They should start with one flick if everything is perfect.
You shouldn't need any additives, I don't even use nitro, but one that's just about guaranteed to give an instant start if you're desperate is ether. How fresh is your fuel?
