Mike B. is correct, the Cub is a floater and if you overpower the full wing version you will be forever trimming it up as it just keeps developing more lift as you increase the speed. [
If (as Mike says) all you want to do is put put around - go for the full wing, if you are planing to use floats - the full wing will get you off of the water easier etc.
Acrobatics will require the Clip wing.
- SO... why not make TWO wings and you can pick and choose as your day progresses?
