RE: ModelTech Sonic 500, need cg and surface travel info
Hi!
10cm is too far back! 8cm is what I have on my Sonic 500 and it is not sensitive in any way. I don't even use dual-rates when I fly, not on any of my pylonracers. You will notice if the plane is nose heavy if you turn sharply, say to the left, only using ailerons. If the nose drops... it is nose heavy! It should be able to do a nice aileron turn without dropping its nose.
Regards!
Jan K
