RE: Pls share pic of your servo/throttle linkage on G26 or similar
This is not your plane but the linkage is the same.
This is a Central Hobbies 2-56 carbon fiber rod with titanium ends. JB Weld is used to glue the ends on. Use 2-56 ball ends on both sides for a slop free, bind free throttle linkage. I like the CF rod setup because it's stiff and strong and you can cut it to a precise custom length (no z bends). The throttle servo is a Hitech 5245 mini digital using the stock aluminum arm that comes with the servo.
