RCU Forums - View Single Post - Float plane conversion and exposed servos?
Old 12-10-2005 | 01:03 PM
JimCasey's Avatar
JimCasey
Default RE: Float plane conversion and exposed servos?
The servo shaft fits pretty tighly and has a big glob of grease on it. You won't have trouble with water inside the servo. Even if the plane dunks, it will float nose down on its back with the tail out of the water. As JustPlaneKrazy stated, your real challenge is to keep water from getting into the fuselage around the servos.
