duration flight help
I should be able to get some thrust numbers tonight. I have a 14 x 6 MA somewhere that I originally had on my 91. I almost think that a 13 x 8 would be more efficient once in the air allowing a lower throttle setting. I'll see if I can get the tests run tonight. I'm sure the engine will put out 6+ pounds of thrust at full throttle for an easy take off.
