RCU Forums - View Single Post - To pushrod or not to pushrod?
Old 12-13-2005 | 08:54 AM
TLH101's Avatar
TLH101
My Feedback: (90)
Default RE: To pushrod or not to pushrod?
I usually run a 4-40 pushrod inside a nyrod outer tube for pushrods on larger aircraft, with as Dr.1 suggegsted, 2 servos and pushrods. A reversed servo is not needed, if you have enough room to put the pushrod on the same side of both servos. Just make sure the geometry is the same on both if you use 2 servos.
