Old 12-18-2005, 09:36 AM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: Futaba Radio T6XA
CCPM is a way of controlling the swash plate of the helicopter and stands for cyclic collective pitch mixing.
PCM and PPM are a way of transmitting a signal from the transmitter to the reciever and have nothing to do with heli's or ccpm.
You will need to get a reciever thats compatiable and on the same channel as your transmitter, your choice will be ppm (fm) or pcm, with pcm being the better and more expensive option of the two. Then you set that helicopter up for ppm or pcm.
The 6xas has helicopter programming and supports ccpm so you will just need a reciever and a flight pack (servos battery etc)
