nitro rustler engine mount BIG PROBLEM
well as many of you know that the nitro rustler with teh trx.pro.15 uses a 2 part engine mount system, 2 pieces that attach directly to the engine, and then the part that attachs to the frame and then engine sits on it, well that part that attachs to the chasis one of the 4 screws has broken off, so i tried drilling it out like last time(last time was cuz i stripped it) and it didnt work, i totally ****ed up the threads, so what i was thinking instead of going to the LHS(its closed anyways, dam katrina) and getting new engine mounts, i thought of getting a bolt that is the same size, put it through the hole, and put a nut on the other end, if anyone needs a better discription please tell me, i need help!!
TIA
