Exactly... depending on how your radios programming does it. Some will have a perearte feature for Ail DIff.... other make you either select Flaperons OR Aileron Diff.
Worst case scenario is that you use endpoints/ATV for the seperate channels to limit the throws to create aileron differential
Consult the all mighty (and often obscure) manual...
