RE: Laser 200 Centre of Gravity Problem
I would start the CG at about 30%from the leading edge of the wing. DO a balance check. Then adjust from there with weight changes. That may be off a little but it wont be in danger of a crash. At least you can get it in the air and figure out its bad flight charcterisitics from the good and see if the CG needs to be moved back or forward.
