RCU Forums - View Single Post - Double Taco
Thread: Double Taco
Old 12-26-2005 | 10:06 AM
  #38
johnyh
Default RE: Double Taco
I managed to get to the local shop just before they closed on Christmas Eve and bought a couple of three blader 9 X 7 so today the test. wow It is so smooth. Still tends to hug the ground before lift off. Even though I have mixed a little flapperon I still haven't used it yet.
And the sound ......
All I can say is if you get the chance or require the push do have a go. It's not difficult and the "buzz" of flying something unique is very rewarding.
Below are some preflight photos.
Unfortunatey mstroh I coudn't go to a 10" prop 'cos the centre section is only 91/2" beam. I originally designed the plane to use 9" props.
Ed I've never had engine run problem with height of the tank, my Mojo has a similar set up with the carb just below or level with tank outlet. I'll attach a photo.
ID:	375775   Click image for larger version
ID:	375776   Click image for larger version
