RCU Forums - View Single Post - How to iron 2nd layer of monocoque w/o bubbles
Old 12-30-2005 | 11:34 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: How to iron 2nd layer of monocoque w/o bubbles
With Monokote, it's easy. Just use Top-Flite "Trim Solvent" instead of heat. Acetone will work too, but it's more agressive than Trim Solvent, and gives you less time to work.
Neither works on Ultracote
For Ultracote, I don't usually have a problem with small or narrow pieces, but for larger pieces I will either remove some of the covering underneath, or poke bazillions of holes in the underlayer to let the air out.
