RCU Forums - View Single Post - modeltech p-47 modifacations, power and props
Old 01-03-2006 | 10:43 PM
  #130
Ticidytoc's Avatar
Ticidytoc
Default RE: modeltech p-47 modifacations, power and props
ORIGINAL: kodak
Okay that worked, here are some more showing gaps between wings. The wing is touching the fillets at the leading and trailing edges but not in the middle.
I built my fillets for my WM P-51 with the wing attached. Minor gaps.
Once its all spruced up and sitting on the runway you will never see the gap. I also use some thin weather strip between the fuse and wing to ward off chafing of the covering.
