RE: horizontal stabilizer not parallel to wing
I'll see if I can remove the stab. Do you have any suggestions? The best I can think of is to try to get a razor blade in there and try to cut at the glue joint without tearing it to pieces. The wing is a two piece connected via two tubes, I wonder if it would be easier to try to straighten the wings because the horizontal stab looks perpendicular to the vertical "stab" (not really much of a stab as an extension of the fuselage). Any help would be appreciated.
G
