RE: horizontal stabilizer not parallel to wing
I have determined that the tubes that are mounted inside the fuse (the wing tubes pass through these) are not square to the fuse, which is causing them to tilt about 1 degree. It seems to me that the correct answer is to correct that problem, but it does not look easy for me to accomplish. That leaves me, I think, with two other options: 1) shim the wings or 2) fly as is and trim out. I'm so confused, this type of problem is new to me. Please continue helping as I have not decided what to do as of yet.
G
