RE: Carden Cuda Build
Last night I started to cut out and fit the bottom deck. For some reason it was short. When down on the bottom of the fuse truss it only came up to just above the bottom of the motor box. I added a strip of 1/8 balsa to the bottom deck and
and now when I add the 1/4" sheet to the bottom of the motor box and shape it will blend a lot nicer.
All the surfaces are hinged and beveled. I need to had the control hard points yet
This evening I plan on setting up the wing incidence. I'm kind of running out of things to do until I have the engine and servos. They should be shipped this week.
