ball links
You folks have convinced me to try ball link connectors in place of or in conjunction with screw lock connectors. I see Tower lists both 1/16" threaded studs and 2-56 threaded studs. Which fit the holes in servo arms and throttle arms? Which is larger, 2-56 threads or 1/16 threads, and/or what is the decimal value of 2-56 threads? I believe 1/16 would be .062. Thanks, guys.
Max
