RE: Replacement Pull-Pull Cable
Yes, very true. I should have mentioned that I slip on some shrink tube and shrink it down where the Kevlar exits the fuse. No matter what you use when the engine is running the cables are going to contact the fuse. Unless the steel cable or Kevlar has a coating use the heat shrink.
Shawn
