RCU Forums - View Single Post - Carden Cuda Build
Old 01-12-2006, 07:44 PM
  #74
ibow24
My Feedback: (10)
Default RE: Carden Cuda Build
Not a whole lot of progress. This part of the build gets slow for me.
Anyway, I'm in the process of setting the wing incidence and adding ply pads and wing bolts.
I measure off the plans and draw a line on the fuse but I also check with a digital level. I set a straight edge on the fuse and block it up to 0.0 Deg. I tape the wings in place so the LE and TE are on the marks I draw (measure from the plans). If I build straight then I should get 0.0 on the level when the wings are set on those marks.
Phewwww...perfect.
Steve
ID:	386405   Click image for larger version
