RCU Forums - View Single Post - Foam to Balsa glue???
Old 11-23-2002 | 12:36 AM
georgehere
Default Foam to Balsa glue???
Hi Guys.. Recently acquired a bottom wing racer. Name on it is "Lucky Lady." The plane took some damage, so I got it for a low price as it has an OS Max .32 with a tuned pipe. The plane seems to be mostly foam. I need to reinstall the wing saddle and wing bolt plate. The plane was a RTF when sold and had the balsa and ply attached to the foam with some kind of glue. I have been told that I can't use CA as it will eat the foam. I have some sandable aliphatic glue that I used when I was sheeting a wing. the damage is so severe that the elevator is now flexible on one side as a result of hard impact, it has lost its rigidity, so I need to build a blasa elevator and attach to the foam body. Appreciate any help.
