RCU Forums - View Single Post - Pull-Pull Wire Holes
Old 01-18-2006 | 02:41 PM
rcbill
Default RE: Pull-Pull Wire Holes
Thanks Ben, I had been reading your threads but evedentally missed that one. I will more than likely do what you did. For the tubing What did you use?? I was thinking of using the the outer tunnel for Sullivan Nyrod. My wife asked me if I had checked my supply of monocote and ultracote. She thought I should have a match because I have several rolls on a shelf. Well she was right. I found the match in about 10 seconds. Like you mentioned it's true red. Just goes to show that sometimes ya get so wrapped up in what you're doing (me) that you just don't think properly.
I would rather go with the servo in the rear but with my DA 50 it would be way out of balance. I already checked that out. ...........Bill
