RE: Drilling for Engine Mounts on Firewall
For the vertical, you measure the distance from the crankshaft centerline on the engine mount up to the top mounting holes and transfer that distance to the firewall. Then measure the distance from the crankshaft centerline down to the bottom mounting holes and transfer that distance to the firewall. The principle is the same.
