RE: Ultimate Engine Mounting
Same as with 3W engines. Something to consider here. If you guys running this engine encounter issues with what appear to be mixture changes in certain flight attitudes, the problem will likely be with the location of this tube. It MUST BE in "dead" air IF it shares the same function as the 3W engine line and ends up to be equally sensitive.
