RE: How Do I Install An Engine?
Most trainers have the correct degree of right thrust and downthrust built into the firewall, so you just bolt the engine into place. Just make sure tht the centerline of the engine shaft is lined up with the thrustlines, and you should be o.k. What kind of trainer do you have? Is it a kit or an arf?
