question regarding the pull pull mechanics
hi,
i have a question regarding the pull pull mechanics. I'm using a 3" servo arm and the distance between the rudder horn is 3", both on the hinge line.
i decided to cross the wires and now one line in full deflection stays loose. is that normal? though, at neutral both the lines are quite tight.
there is a diagram at the SWB website of different ways to setup the rudder. in that with a cross setup the servo arm has a small off-set and it's also a bit smaller.
should i do the same or should i stick with what i have. the problem in changing is that i live in india and i would have to get the proper setup from the US.
thanks
