ORIGINAL: rsrogers
Could someone post a direct link to the thread zooland is talking about. Cant seem to find it & would like to set my 9C up as well for my Blade.
Dosent it take a single conversion Rx. crystal?
Yes, I used a single conversion Futaba Rx Xtal in mine and it seems to work. The following is a setup I got from the page the other guy was talking about, I think. I can no way take any credit for the programming. Just can't remember who the guy was. I'm gonna have to go back later and thank him. However the setup seems to work so far. I'm new at this and just skidding and hopping around and trying to get sometype of control on this little beast. Ha! Ha! Anywho, here is the setup:
First set it for PPM. NOT PCM
Pick swashplate type SR-3
Goto SWASH AFR
make ailerons -50%
make elevator +58%
make pitch +64%
Goto END POINTS
make throttle 43/100
Goto REVERSE
reverse the ailerons, and the throttle
Goto PIT-CV/NOR
Point 1 46.0%
Point 2 52.5%
Point 3 57.5%
Point 4 63.5%
Point 5 75.0%
Goto TH-CV/NOR
Point 1 0%
Point 2 25.0%
Point 3 50.0%
Point 4 75.0%
Point 5 100.0%
Goto REVO./NOR
Mix = ON
Point 1 -20%
Point 2 -10%
Point 3 0%
Point 4 +10%
Point 5 +20%
Goto the advanced menu
Goto HOV-THR
MIX = ON
Turn the VR(c) knob till it reads
RATE=0% (-71%)
Goto HOV-PIT
MIX = ON
Turn the VR(a) knob till it reads
RATE = 0% (+10%)
This is just the set-ups for normal mode.
Good luck on your blade......
