RE: MPI Onboard Glow Driver
I wouldn't think that a glow plug would care which way the polarity was. You have hooked it up the same way as the instructions except that you reversed the battery polarity. The question I have is when you use this on a twin and split the lead to the glow plugs, you only get half the voltage to each glow plug. Therefore should I use two batteries?
james
