RCU Forums - View Single Post - cheap field stand
Old 01-31-2006 | 06:03 PM
more power
Default cheap field stand
every one is familare with the PVC stand that sits on top of your table, makes a great building stand a couple of 90 degree bends a large V to cradle the plane. but at the field it takes up a lot of room on a portable table and is un safe for a larger running plane to make any adjustments .. so get two 18inch c clamps or wood clamps 10.95 each that wiil be the square type available at any building center. 10 ft of 1 inch thick wall pvc 3.95 four 90 degree elbos .59c each two T s .60 each, cut two 18 inch up rights slip over the square stock on the clamp add the Ts cut four short lenghts to fit the size of your planes add the 90 degree and add the short up rights to keep the plane in place you should add the safty foam to protect your plane .. will fit any table and keep your table free and clear for your flight gear. for less than $30.00. for extra safty I did notch the table to let the flat stock lock into the table sides
