RCU Forums - View Single Post - glueing large areas
Old 01-31-2006 | 10:42 PM
Campy's Avatar
Campy
Default RE: glueing large areas
I have tried the "all CA" method. I found that unless I work quickly, the CA (slow setting thick ) has a tendency to set up before the sheeting is properly in place.
The wood glue, while taking a looooong time to dry (usually several hours ), gives you plenty of time to get everything right without the worry of the glue setting up on you.
