RCU Forums - View Single Post - TRU-TURN SPINNER
Old 02-05-2006 | 07:24 AM
Newc
Default RE: TRU-TURN SPINNER
You can also get the 7mm x 1.25mm spinner adapter from MPI for about $3.50. It is a double nut set w/o the bolt. If you order the spinner directly from them, they will replace the stock adapter with whatever you need just for asking.
Same is true for Tru-Turn. I've had very good dealings with them.
