RCU Forums - View Single Post - Casting rubber tires
Old 02-08-2006 | 12:52 PM
meowy84
Default RE: Casting rubber tires
Scott, I was thinking of having solid tires (easier to cast than trying to make them hollow). Also I think you'd almost have to use some sort or 2 part RTV to set (where air is not required) because if you use a mold where the air supply is closed off the thing might not want to cure.
