RCU Forums - View Single Post - Cellpro 4s Balancing Charger
Old 02-15-2006, 12:30 PM
Greg Covey
Greg Covey's Avatar
Default Cellpro 4s Balancing Charger
FMA’s new Cellpro 4s Charger is part of a revolutionary new lower-cost LiPo battery and charge system for R/C aircraft. With an automatic 1C charge rate of up to 4 amps, the charger brings your Cellpro compatible packs up to charge with unprecedented safety and accuracy! No knobs, buttons, or jumpers to set - the cell count cannot be wrong!
A built-in LCD display shows you charging information and a pack fuel gauge. The PC interface allows for a complete graphical display of each cell in the pack using the free FMA 4s Charger Viewer Software.
FMA’s Cellpro Node Connector is a key part of the system. It enables the charger to monitor individual cells and independently charge each cell to its optimum level.
Charge protection dramatically improves pack performance, pack life and charging safety. The Cellpro 4s charger may be used to charge only FMA's new Cellpro Kokam and Cellpro Slimline 2s to 4s LiPo packs.
Cellpro 4s Charger Features:[ul][*] LCD Screen shows all 4 battery voltages with 1/10% accuracy full scale, current, supply voltage, Amp Hrs, Fuel Level and Charge mode[*] The charge current in amp hours is factory calibrated to +/-1% accuracy[*] A built-in speaker signals charging finished[*] The Auto-current setting will charge any battery less than 3.5Ah in 50 minutes or it can be manually set to 0.25 to 4 amps in 0.25A steps[*] The free 4S viewer software shows everything in graphical format[*] Battery Restore mode will fix over discharged cells[*] Special wire compensation allows 10mV accuracy on any length charge wire
[/ul]
Don't let your old charger guess the wrong cell count again! Using the lower cost Cellpro 4s charger guarantees the correct cell count.
[link=http://www.fmadirect.com/Detail.htm?item=2116&section=45]Cellpro 4s Charger[/link]
[link=http://www.fmadirect.com/products.htm?cat=45&nid=4]Cellpro Products[/link]
