Hi Bassman,
I am working on finishing up the 2nd wing. I took a break lastnight and spent the evening with the wife
I will completely build the fuse for the 1st coupe before staring the 2nd and hopefully learn from any mistakes and correct them on the 2nd one. I am taking alot of pics of the build and taking notes as I go. I will be more than glad to help you get beyond your stopping point if I can. I have read your post and I have seen what you have done with the rudder set-up, it looks like it should work good. Did that modification add too much weight in the tail?? to me it looks a little heavy. That probably would not be an issue with the engines I will be useing in the planes anyhow.
Here are a couple of pics of the right wing panel with the sheeting applied and the wing tip rough sanded, these wings are very strong and light when finshed.
Later!!
Anthony
