RCU Forums - View Single Post - Adjusting Blade CP to use Futaba 9C
Old 02-16-2006 | 04:39 AM
motorsports
Default RE: Adjusting Blade CP to use Futaba 9C
Hey rsrogers, sorry it took so long but I was finally able to check the freq on my Blade vs the Futaba transmitter. The transmitter was on Ch 57 and the Blade was on Ch 52. So I know that's not much help to ya. Both were technically on the same band. Sorry. Still sticking to the idea of the range test deal. If it passes that you are good to. I know I read somewhere on here about how broadbanded the RX was and the band didn't matter.
OK, just whacked a brand new set of blades on test flight after rebuild. My stupid. But got a nice pair of back scratchers now. (Tape them together for length!)
And BTW, the gov't should require model companies to put eye charts on the box! Ha! Ha! "If you can't read this you can't see well enough to work on this!" Ha! Ha! And yes I've tried the maginfiying visor. Just maginfies the shaking too! Ha! Ha! Maybe I should just stick to the Playdoh classes!
