RE: PROBLEMS WITH MOKI 210 - NEED HELP
Make sure that you have proper air flow over the engine. Also make sure that it is tuned very rich for the first few gallons. It should not turn hard unless it's the compression causing it. Once it cools down, is it still hard to turn between compression? Should turn very freely between the compression spots.
