Removing the wing droops will give you more of a precise roll.That is as well as the Nexstar can do a roll.I learned on the Nexstar and when everything was removed it was easier to control the plane. You do have to use rudder and ailerons in the same direction and be aggresive with them to get a decent roll rate.
Speed also increases some with all the aids removed.
