RE: running paint
Patience is the key. Very light coats, one at a time, allowing each to dry, will give you the results you need. I don't think you can remove a portion of the dried paint without sanding it off. You'd have to be VERY careful though. I don't know, maybe just consider starting over again would give you better results.
