RCU Forums - View Single Post - Pull Pull cables exposed???
Old 12-02-2002 | 06:08 PM
WwpIII
Default Pull Pull cables exposed???
thanks for that info.....the only problem i figured i would have would be flutter from the cable....i have used pull pull systems several times but i have never had near this much of the cable exposed to the outside of the plane...my plan on using this set-up is a big deviation from the way the manual shows, but i feel this would be a good move, i hate them split elevator "torque rod" hook-ups...i considered going with the mk bellcrank and using the set-up as is, with one elevator servo...but the reinforcement needed would be more than what i would want to do...
