ORIGINAL: Richard L.
The general rule of thumb is that the air exit hole must be at least twice the area of the air inlet hole.
Yeh, possibly at equal pressures. However, the final size will be about the same size as the inlet seen in the picture....so your general rule of thumb will still be true. However, it be at positive pressure. A positive inlet pressure will reduce the likely of stagination.
