RE: 4 stroke engine problems
Your friend is right Cambo. If you decide to get an onboard glow, make sure the battery that comes with it is at least 1100 mAh. The kind I have has a pilot light that you can mount in the cockpit to observe when the glow is working. Mine Y's into the throttle servo and can be adjusted to only come on at idle.
