RE: DA 100 IGN FAILED
Hello Spectre1,
Just a thought here, but if you are using the red and black ign plug from the module when it is new, you may want to check to see that it did not break at the connector pin that are crimped on to the wire. I have had these wires break but only after I had run the engine for some time. Just something worth checking.
