Flight time
Fuel tank manger
Hi! Jim, first the fuel go into the hopper tank, when it is full, it goes through a T-join and go into the main tanks, ( that's mains two fuel tanks that located close near the C of G point) and than when this two main tanks get full of glow fuel, it goes from this two fuel tanks to another two fuel tanks that is located may be about the C of G, because when you start the engine, you will using this two fuel tanks glow fuel first, a little bit nose heavy is acceptable when you takeoff, after a few minutes, when this two fuel tanks are empty, you will have the corrected C of G.
You don't have to worry the supply of the fuel, just put your back pressure from the pipe and fit it to the last two fuel tanks use the T-join, you will have enough fuel for the engine.
