RE: BME Aircraft 30% Extra330L
Joe,
It's not needed in my case. I have the aluminum end screwed all the way in and adjust as needed on the nylon 4/40 ball link. I managed to cut the CF pushrods perfect and did not have to adjust anyway.
Y N C,
Max just said some time in April. I think he is holding off on an exact date until these things hit the water.
I have the batteries installed and the CG is almost at six inches. All the batteries (three 2400 Fromecos) all located where the rudder servo is mounted. The regulators are located at the wing tube which is at 6 1/2 inches back. It should be a good place to start. Sealed all the hinge gaps with white Monocote I had laying around.
Ken
