Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
Reload this Page >
Hacker A30-12XL v2 motor problem
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 08-25-2012, 02:59 PM
3dsky
My Feedback: (84)
3dsky's Avatar
Default Hacker A30-12XL v2 motor problem
Running a Hacker A30-12XL v2 motor on 4S using the Hacker X-70 SB PRO ESC, when I advance the throttle stick the motor starts backwards slow. How do I fix this. I also tried a different motor and had the same result
Old 12-11-2012, 07:26 PM
Natsirt
Default RE: Hacker A30-12XL v2 motor problem
Have you tried adjusting the timing in the ESC? I believe timing is usually the culprit when motor won`t spool up (unless motor or ESC have actually packed it in). If motor spins in reverse, swap any 2 of the 3 motor wires.
Old 12-11-2012, 07:41 PM
3dsky
My Feedback: (84)
3dsky's Avatar
Now using a ICE 75 and motor works great. Acceleration is much better. I had the Hacker ESC cog at startup and start in reverse very slow. I did try to program but did not help. I also re-soldered and used larger connectors still no change. Sending it back. I normally only use Castle ESC’s and I learned my lesson.
