Brushless motor for the Shock Extra
I was going to buy a Shock Flyer Extra 330 and was wondering if the stock motor was ok. Do you think I should pay the money for the brushless? Will it hover and do 3D with the stock motor?
Thanx
Thanx
MN
RE: Brushless motor for the Shock Extra
Here is some good reading on that subject. [link=http://www.rcuniverse.com/forum/Maiden_on_Shocky_Edge_with_3D_power_setup/m_1531137/tm.htm]Stock Shock Flyer[/link]
For indoors I prefer the Nippy Black 0508 with 3S 340 pack and an APC 11x4.7.
MN
Here is a quick video of my Shocky with the Nippy 0508.
[link=http://www.happyhangar.com/displayimage.php?album=88&pos=6]Shocky Clone[/link]
FL
I have a AXI 2808/34 on my Shockie Edge and the performace is great on 2 cells. No shortage of thrust here. My AUW is 6.5 ounces ready to fly with a Kokam 340 2s1p pack. The axi is a very well built motor. I can not wait to get ahold of a 340 3 cell pack to try. Heard 3 to 1 power to weight ratio with 3 cells.
MN
Capt.
I haven't actually timed it but at least 7-9 minutes guessing. Long enough that I'm ready to come down when they start getting low. I love this combo, especially with 3S! [8D] MX-30 servos.
I have a 3s on mine with an axi2208/34 . I wouldnt call the power dumb. It is pretty intense though. I also fly it with a 2s and it is much easier to manage.
My Feedback: (38)
I got to fly boom3's shocky with the AXI setup, holy cow, you can flutter the ailerons on vertical!! And do it for over 13min!!
I put a Nippy 0508 on mine, and not near the awesome performance he has, if I did it all over, Id go AXI!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
ok so i read all the posts here....i have the 330 s version.i bought a cc pheonix 25 for cheap, now i need a motor, and battery..i want unlimited verticle.. im leaning towards a 2208/34 and a 2 cell or 3 cell lipoly system...my question is do i want the 2808 or the 2208 axi, also what prop adapter do i buy for the motors and whts the best props to run?
Wow
Just flown my Shockflyer for the first time - this is by far the easiest plane I have ever flown.
It hovers at just under 1/2 throttle. Knife edge is brilliant and KE loops no problem. This is the first plane I have has that is as easy to fly as a simulator. I was even torque rolling at 10' on the maiden - which I have never done below about 100' before. No problem pulling out of a hover. I just need to keep a closer eye on time because I put 343mAh back in after the flight and I hadn't even noticed a drop in power! Hope I haven't damaged it.
Setup is AXI2208/34 Jeti-08 with APC 10x4.7
Kokam 2s340
servos Saturn4.4
JR 700 Rx - case removed
AUW is only 7oz (200gm)
I am off out to give it another test fly - more spectators this time though ...
Kevin
Kokam 2s340
servos Saturn4.4
Kevin
Oohhh i will have just enough to get one by next month!!
Is that the edge you have 3drcheli?
Which shop did you get it from? West London Models?
hey krazy u ever get that shocky? I just slapped together the 330s w axi 2208/34 i use a kokam 3s 340 or the kokam 2s 1500 must say be gentle u can rip the wings off going vertical also these wings wont hold the stree on powered loops the g's will fold the wing up! i ready to build a foam factory type now maybee the Sukoi or something 1st i have to sell my heli
Hi folks!
I'm in the building process now (Shocky Superstar) with a AXI 2208/34. The building instructions are no good []
How do you mount the engine? Does anybody have a good picture of the front of the airplane?
Thanks a lot in advance!
Lars
Lars
OK
Check out the brushless motor mounting instructions for the shockflyer at www.hobby-lobby.com. Works well.
Coolair
Coolair
