Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
Reload this Page >
What brushless for wattage ultimate bipe?
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 04-19-2004, 06:27 AM
mrgastone
Default What brushless for wattage ultimate bipe?
Hi all,
i would like to upgrade my cobalt motor to a brushless. Any suggestions for an high performance brushless to install on my wattage ultimate bipe?
Thanks in advance,
Mr Gastone [8D]
Old 04-19-2004, 06:00 PM
crashingagain
Default RE: What brushless for wattage ultimate bipe?
Himax 2025 series, KV rating dependent on battery, flying style
Old 04-20-2004, 06:26 AM
mrgastone
Hi,
i would like to use a Sanyo CP 1300 7 cell......it's ok for that motor?
Thanks again,
Mr Gastone[8D]
Old 04-20-2004, 06:02 PM
crashingagain
you are probably going to want to run at least 8 cells or even more to really bring the power out of a brushless
Old 04-21-2004, 09:58 AM
enrique1123
enrique1123's Avatar
if you want to go brushless go to at least 8 cells, brushless like the juice, the AXI 2808/16 would be a great choice, I run it on a Mad Dog that came with a Cobalt 400 27 turn, I run it with a 3 cell TP LiPo and it blows everything away, unlimited vertical.
Old 12-17-2004, 12:23 AM
boosted180
My Feedback: (8)
which how many mah is your lipo and how many c discharge? i have a 3 cell 1500mah 8c and would definitley consider getting the axi motor if my battery cna handle it.
also what size prop? no gearbox, right?
thanx,
brian
Old 12-20-2004, 09:50 AM
Sturtz
My Feedback: (20)
Sturtz's Avatar
I'm running a PJS1000 - Jeti30 ESC and a Tanic 3S 2150. 11x4.7 APC prop
Unlimited vertical. Very fast. You need to land with just a tad of power on with the Bipe. Stopped prop will act as a brake slightly.
Although the plane hovers in at a nice slow speed , the wing loading is a bit higher with biplanes in general.
ID:	204886   Click image for larger version
Old 03-13-2014, 07:16 AM
Mark@ny
What other electric motor is equal to a PJS1000
Old 03-13-2014, 07:41 AM
Dr Kiwi
The PJS 1000 is an 85g 1000Kv motor rated for 25A... so...this is pretty close: http://www.hobbyking.com/hobbyking/s...00kv_380w.html
