Axi Motor 2208/34
Axi Motor 2208/34
I have just bought a yak 54 shock flyer and an axi motor, i wanted to mount it with a back plate, but i couldn't get the grub scew out as it was done up unbelievable tight to switch the shaft round. Has any one had this problem? and please could any one attach a photo of how you have mounted a Axi motor to some sort of shock flyer.
Rob
Rob
RE: Axi Motor 2208/34
ORIGINAL: rob61
Rob
Rob
Most are using the radial mount kit. I knew of one person that swapped his shaft around, but he had to file another groove for the c-clip and it just got messy. Are you trying to swap the shaft as a cost effective solution?
-Mike
Mike,
iam trying to swap the shaft around so in can mount it with a back plate because i think that it looks better.
Rob
Rob
